Issues with check_http service definition
stecino
Post by stecino »
Hi all This is what what I have
host_name gamepass.nfl.com
service_description https://gamepass.nfl.com/nflgp/secure/packages?
check_command check_https!6!8!'/nflgp/secure/packages?wl=JAC&team=JAC&nlrefer=JAC'
notifications_enabled 1
when trying to reloading nagios I am seeing
Error: The description string for service 'https://gamepass.nfl.com/nflgp/secure/packages?' on host 'gamepass.nfl.com' contains one or more illegal characters.
when I run this explicitly, and bellow is following the check_https command definition
[root@stageutil01 libexec]# ./check_http -S -H gamepass.nfl.com -w 6 -c 8 -u '/nflgp/secure/packages?wl=JAC&team=JAC&nlrefer=JAC'
HTTP OK: HTTP/1.1 200 OK - 8616 bytes in 0.460 second response time |time=0.460193s;6.000000;8.000000;0.000000 size=8616B;;;0
How do I setup URI in the service definition so that nagios reload takes it
gshergill
Re: Issues with check_http service definition
Post by gshergill »
Hi stecino,
The issue is with the following line:
The illegal character is the "?", you would need to remove it for the reload to pass.
Kind Regards,
Gary Shergill
stecino, let us know if gshergill's suggestion solved your problem.
stecino
Post by stecino »
Thanks did the trick!!!
