Hi *,
Configuring passive checks, I'd like to see >how< old is the last data when a service becomes stale.
The 'no-backup-report' command in http://nagios.sourceforge.net/docs/3_0/freshness.html does
not show that. I can imagine a complicated way around (associating a file with every passively checked
item and checking the age of the file), but that's really ugly.
Better ideas are most welcome.
Thanks, jvejv
Age of stale passive checks
Re: Age of stale passive checks
You could always add the freshness value to the duration of the stale status to get a total.
Thanks, that's not bad
OTOH, it would be nice to have that summed by Nagios. Is there a way to get the age of the data from the last passive check of a service into a plugin ?
What do you mean by getting it into a plugin? Are you talking about the age of a passive check result? You could scape this directly from the nagios.log file, though we don't have a guide on scraping information from there with custom plugins you could use a similar method that some of the log file plugins use.
Thanks for the hint - I'll try it.
Well let us know if we can be of more help!
