Escalation notification interval
If in escalations I do not supply a "notification_interval", will that cause an error or will it then use the notification interval of the host or service?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Escalation notification interval
It is a required field for escalations, so the configuration will bail out with an error if you try to save it without one.
I suspected that, but just wanted to make sure without having to test myselfslansing wrote:It is a required field for escalations, so the configuration will bail out with an error if you try to save it without one.
Feel free to close this thread!
