Dear all ,
Greetings ,
I have some issues with nagios xi, some of them are jotted down below
1) I get lots of logs in my windows server stating that nagios event is firing it.
2) Also i am monitoring sql server , but i am seeing 14 to 15 concurrent connections from nagios , is it a proper behavior from nagios or there is something wrong in the configuration ?
Nagios event floods
Re: Nagios event floods
We need a lot more depth on this statement, what are you trying to do here?I get lots of logs in my windows server stating that nagios event is firing it.
Is this your nagios XI mysql database you are monitoring? Then it is quite possible. If you are running multiple checks to the database then this is also possible.Also i am monitoring sql server , but i am seeing 14 to 15 concurrent connections from nagios , is it a proper behavior from nagios or there is something wrong in the configuration ?
