Nagios Core Databse
sagarshah1983
Nagios Core Databse
Post by sagarshah1983 »
Hello all,
I have got some basic insight on installation and running of nagios core tool so far.
I see that most of the information about monitored services are pulled from status.dat file, is that correct?
If so, status.dat alsways reflect the data of last check made by nagios. But does it store data historically anywhere?
For example, as on last hour, one http service went down and showing red on web console and same is reflected in status.dat as well.
But once, the service comes up, status.dat also shows OK for the service and same in the web console as well, does that issue (of service being down) is tracked/stored anywhere as a part of historical data?
What is the ideal way of pulling these service related data from Nagios? Is it status.dat file only? Or can it be put in any database as well?
Please advise.
Thanks.
Regards,
Sagar Shah
abrist
Red Shirt
Re: Nagios Core Databse
Post by abrist »
status.dat = current state/status
objects.cache = core configuration
nagios.log = historical information
Historical information can be stored in a db, I suggest NDO:
http://exchange.nagios.org/directory/Ad ... ls/details
