Solaris 10 nagios agent
veenm
Post by veenm »
HI ,
Please let me know the Nagios Core agent for Solaris 10 servers. Where can i download the binaries .
abrist
Red Shirt
Re: Solaris 10 nagios agent
Post by abrist »
veenm
Post by veenm »
Please let me know steps to install the nagios agent on Solaris 10 SPARC servers is same for nagios XI and Nagios core is same or different .
Post by slansing »
It will be the same for both, and it is outlined in the above documentation.
veenm
Post by veenm »
I have Nagios Core version 3.5.1 and i want to monitor the solaris 10 (SPARC) and please let me know which is the best document to refer.
http://assets.nagios.com/downloads/nagi ... _Agent.pdf
http://exchange.nagios.org/directory/Pl ... 29/details
What are the difference between below 2 URL steps...
Does this need compiler ?
abrist
Red Shirt
Post by abrist »
The exchange package is community made whereas the assets package (from the doc) is built and maintained by Nagios. They are both binary packages. Depending on what dependencies you have available in your solaris 10 zone, these may or may not work for you. Give them a try on one of your test boxes first.
veenm
Post by veenm »
is it not 100% confirmed that it will work , if it did not works then what are the other option that we have to install nagos agent on solaris
abrist
Red Shirt
Post by abrist »
Compile from source and deal with the mess that is solaris dependencies (I am looking at you SUNW_* and lib.so . . . .)
I would suggest trying the binary packages first.
veenm
Post by veenm »
If i follow below link , will it work ?
http://utahsysadmin.com/2008/03/14/conf ... olaris-10/
abrist
Red Shirt
Post by abrist »
That is for building it from source. A number of people have reported that it worked for them, while others have had dependency issues. Have you tried the binary packages?
