Greetings,
I previously posted about graphing performance metrics historically. I have found everything working great, but am lacking 1 thing in order to replace my existing Capacity Management tool.
I need the ability to grab process level details (such as top 10 processes) and then graph them out to CPU usage, Mem, Disk I/O. From what I have looked through in the existing plugins, I do not see anything that fits this criteria. Am I not looking in the right place? Is this doable?
Thanks everyone.
Chris
Top 10 Processes...
Re: Top 10 Processes...
This is something close to what we are working hard towards for a future release, you will be able to stack performance graphs together. However there are currently no plugins which will check the top 10 processes then figure out what their usage levels are. This is something that could be created though. If you do look at doing this you will need the plugin development guidelines:
http://nagiosplug.sourceforge.net/devel ... lines.html
