Install with no internet
BanditBBS
Post by BanditBBS »
I want to install another XI instance in one of our data centers. The problem is, there is no internet access for machines residing there. Is there any way to get the installation to work without an internet connection?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
BanditBBS
Re: Install with no internet
Post by BanditBBS »
it looks like it failed on the yum part. not sure if this server can see out satellite server either. I will verify that if it should be able to, that it can. otherwise, not sure how to get it working.
Post by slansing »
Hey Bandit, if you send a PM off to spenser he may be able to help you out with this.
