Errors after restore to new system
bbraunsc
Post by bbraunsc »
I restored a backup of my production system to a newly installed CENTOS box and I can't get it to run.
The Monitoring Engine, Performance Grapher and Database Backend services won't start. And Under the Config file Permissions Check I get an error.
So I ran the below command to verify the installation and I'm getting an error on the contacttemplates.cfg
./nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 3.5.0
Last Modified: 03-15-2013
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Error: Cannot open config file '/usr/local/nagios/etc/contacttemplates.cfg' for reading: No such file or directory
abrist
Red Shirt
Re: Errors after restore to new system
Post by abrist »
You are missing your contacttemplates.cfg file. Was this part of your backup?
