Monitor Windows failover cluster in Nagiosxi
alabzhinov
Post by alabzhinov »
We need to monitor our Windows 2003 failover clusters (Exchange and SQL). Is there any way to do that from NagiosXI ?
I would appreciate any help, for now I'm stuck with that.
Thanks.
tonyyarusso
Re: Monitor Windows failover cluster in Nagiosxi
Post by tonyyarusso »
The Windows Server wizard will let you set up monitoring for each component of the cluster, but I'm not aware of anything specific to the cluster itself.
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
alabzhinov
I found one good script for that. It allows to monitor specific resources and nodes within the cluster.
http://exchange.nagios.org/directory/Pl ... B)/details
You could implement it using NSclient++ and Nagios Core Config. It is vbs script so it is easily customizable.
