localhost and switch status Down
csandy1703
Deal All
I have installed NagiOS 4.0.0. with no errors.
However after opening nagios interface, localhost status is DOWN always.
Also I added one switch in /usr/local/nagios/etc/objects/switch.cfg, but it also showing DOWN.
Pl help
Pl help
volpeadmin
Re: localhost and switch status Down
I'm also having this same problem...I've found threads elsewhere outside the official support forum that suggest the service.cfg and hosts.cfg should be checked for syntax errors, etc, however after a clean install on my part, I don't find those files anywhere...
In a clean install, localhost.cfg should hold these config objects. What is the listing of the directory:
ls -la /usr/local/nagios/etc
ls -la /usr/local/nagios/etc/objectsFormer Nagios employee
volpeadmin
# ls -la /usr/local/nagios/etc
total 76
drwxrwxr-x. 3 nagios nagios 4096 Sep 24 15:35 .
drwxr-xr-x. 8 root root 4096 Sep 18 14:46 ..
-rw-rw-r--. 1 nagios nagios 11669 Sep 18 14:46 cgi.cfg
-rw-r--r--. 1 nagios nagios 26 Sep 18 16:35 htpasswd.users
-rw-rw-r--. 1 nagios nagios 44710 Sep 18 14:46 nagios.cfg
drwxrwxr-x. 2 nagios nagios 4096 Sep 25 09:17 objects
-rw-rw----. 1 nagios nagios 1340 Sep 18 14:46 resource.cfg
# ls -la /usr/local/nagios/etc/objects
total 56
drwxrwxr-x. 2 nagios nagios 4096 Sep 25 09:17 .
drwxrwxr-x. 3 nagios nagios 4096 Sep 24 15:35 ..
-rw-rw-r--. 1 nagios nagios 7716 Sep 18 14:46 commands.cfg
-rw-rw-r--. 1 nagios nagios 2166 Sep 18 14:46 contacts.cfg
-rw-rw-r--. 1 nagios nagios 5408 Sep 25 09:17 localhost.cfg
-rw-rw-r--. 1 nagios nagios 3124 Sep 18 14:46 printer.cfg
-rw-rw-r--. 1 nagios nagios 3293 Sep 18 14:46 switch.cfg
-rw-rw-r--. 1 nagios nagios 10812 Sep 18 14:46 templates.cfg
-rw-rw-r--. 1 nagios nagios 3208 Sep 18 14:46 timeperiods.cfg
-rw-rw-r--. 1 nagios nagios 4019 Sep 18 14:46 windows.cfg
total 76
total 56
Well, you have a localhost.cfg, and it is not empty. Is the objects folder included in the nagios cfg?
grep cfg_ /usr/local/nagios/etc/nagios.cfgFormer Nagios employee
volpeadmin
cfg_file=/usr/local/nagios/etc/objects/commands.cfg
cfg_file=/usr/local/nagios/etc/objects/contacts.cfg
cfg_file=/usr/local/nagios/etc/objects/timeperiods.cfg
cfg_file=/usr/local/nagios/etc/objects/templates.cfg
cfg_file=/usr/local/nagios/etc/objects/localhost.cfg
#cfg_file=/usr/local/nagios/etc/objects/windows.cfg
#cfg_file=/usr/local/nagios/etc/objects/switch.cfg
#cfg_file=/usr/local/nagios/etc/objects/printer.cfg
# extension) in a particular directory by using the cfg_dir
#cfg_dir=/usr/local/nagios/etc/servers
#cfg_dir=/usr/local/nagios/etc/printers
#cfg_dir=/usr/local/nagios/etc/switches
#cfg_dir=/usr/local/nagios/etc/routers
# object configuration files (see the cfg_file and cfg_dir options above).
sreinhardt
- -fno-stack-protector
By default the host checks are just check_ping. Have you verified that your host is allowing responses from icmp packets and allowing them output or that your switch is responding to them?
volpeadmin
# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT tcp -- anywhere anywhere tcp dpt:http
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
ACCEPT icmp -- anywhere anywhere
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:ssh
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:5903
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:5902
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:5901
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
sreinhardt
well, everything looks good there. Let's do a ping to both and just be 100% sure that icmp is working.
volpeadmin
# ping -c3 152.122.15.15
PING 152.122.15.15 (152.122.15.15) 56(84) bytes of data.
64 bytes from 152.122.15.15: icmp_seq=1 ttl=255 time=0.469 ms
64 bytes from 152.122.15.15: icmp_seq=2 ttl=255 time=0.557 ms
64 bytes from 152.122.15.15: icmp_seq=3 ttl=255 time=0.425 ms
--- 152.122.15.15 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2000ms
rtt min/avg/max/mdev = 0.425/0.483/0.557/0.060 ms
# ping -c3 localhost
PING localhost (127.0.0.1) 56(84) bytes of data.
64 bytes from localhost (127.0.0.1): icmp_seq=1 ttl=64 time=0.070 ms
64 bytes from localhost (127.0.0.1): icmp_seq=2 ttl=64 time=0.018 ms
64 bytes from localhost (127.0.0.1): icmp_seq=3 ttl=64 time=0.042 ms
--- localhost ping statistics ---
rtt min/avg/max/mdev = 0.018/0.043/0.070/0.021 ms
