Monitoring Dlink switch CPU and Memory utilization
anoop
Post by anoop »
Hi Team,
We are trying to monitor D-Link Switches in XI, but we are not able to monitor D-Link Switch CPU and Memory Utilization.. We checked the snmp query output, but not able to find the OID of the same..
Please provide us an OID or any plugin to monitor D-Link Switch CPU/Memory Utilization..
Thanks for your help in advance....
System:
Nagios XI Version : 2012R2.2 | PHP Version: 5.3.3
Offloaded MySQL DB on another virtual machine
16 CPU with 2 cores each | 32 GB RAM | 1 TB HDD
CentOS-6.3 |Total = 4,000 hosts| 40,000 services.
abrist
Red Shirt
Re: Monitoring Dlink switch CPU and Memory utilization
Post by abrist »
I think you have it the other way around. You will have to supply a MIB or search through the technical documentation for *your* device in order to produce a valid OID. Have you contacted the vendor for MIB/OID documentation?
