?Bug? Cannot declare main config variable.
jbowen7
Post by jbowen7 »
I'm getting this error when trying to use a main configuration parameter that, in the documentation for Nagios Core 3, is available to use:
root@gorgon:/etc/nagios3# service nagios3 restart
 * Restarting nagios3 monitoring daemon nagios3
Nagios Core 3.2.3
Copyright (c) 2009-2010 Nagios Core Development Team and Community Contributors
Last Modified: 10-03-2010
License: GPL
Reading configuration data...
Error in configuration file '/etc/nagios3/nagios.cfg' - Line 1337 (UNKNOWN VARIABLE)
   Error processing main config file!
     directives and data defintions.  If you are upgrading from a previous
     may have been removed or modified in this version.  Make sure to read
 * errors in config!
Here's the variable in question:
root@gorgon:/etc/nagios3# tail --lines=+1336 nagios.cfg
# Allow Empty Hostgroup Assignement
allow_empty_hostgroup_assignment=1
Also I tried setting debugging like so:
debug_level=-1
debug_verbosity=1
But /var/log/nagios3/nagios.debug doesn't seem to get written to, unless the main config is fine.
Anybody have any suggestions?
abrist
Red Shirt
Re: ?Bug? Cannot declare main config variable.
Post by abrist »
This directive was not introduced until after 3.2.3, so you would have to upgrade nagios in order to use it.
More information: http://tracker.nagios.org/view.php?id=210
jbowen7
Post by jbowen7 »
Ah hah!! thanks.. that alone is worth compiling for source to me.
Thanks again.
abrist
Red Shirt
Post by abrist »
No problem. Cheers!
