Nagios Business Process Intelligence
rdhall01
Post by rdhall01 »
Started to look into BPI today and the page comes up but just a spinning icon, so I tried it on IE and it works this must be a bug /chrome issue.
version of chrome used is Version 29.0.1547.76 m
version of IE used is 9.0.8.112.16421
Re: Nagios Business Process Intelligence
Post by slansing »
What portion of the page was spinning? Did you access BPI through Home > Nagios BPI? Is the throbber in the middle of the page spinning? Just tried it with 29.0.1547.66 m and it seems to be working fine. Can you try accessing this page after running the following from the command line?:
tail -f /var/log/httpd/error_log
And once the page sits there for about 10 seconds or so stop the log tail and send the results here, thanks!
Do you have any custom extensions in your chrome install?
