On 05/09/2011 02:55 PM, Roberto Oppedisano wrote:
> It appears that the problem happens on services member of both
> Contact-Center, INS_Backbone servicegroups; i did not verify
> all of them (only a visual inspect) but did not find a contrary case
> 'till now.
And those are *exactly* the two servicegroups with the longest "member"
line in your objects.cache diff, which lends weight to the environment
overload theory.
Do you use environment variables in the first place? (I.e., a plugin,
event handler, notification command etc. which reads a $NAGIOSsomething
variable from its environment, rather than having it passed on the
command line through a $something$ macro in the Nagios config.) If not,
try setting "enable_environment_macros=3D0" in your nagios.cfg (it's
usually a performance boost, anyway).
Kind regards,
J. Bern
--=20
7
Unternehmenssitz Weiterstadt, Gesch=E4ftsf=FChrer Metin Dogan, Oliver Mic=
hel
