[Nagios-devel] Performance Data questions
Started playing with Performance data information and had some questions about
possible options.
I have modified some plugins to return the proper "| item=val"
after the basic plugin return codes so I can gather data.
I see the reasons why not to use performance data handler command and so I
enabled the file option. One feature I would like is for Nagios to only put
data in the performance log if perfdata is specifically outputed. In my case I
don't want to see anything in those files except for plugins that output
specific performance data and not generic $OUTPUT$ data. Is something like this
already an option ?
Side note. The ability to have seperate colors in the css files is great !
thanks for the new feature. One word of warning though. Back up your
stylesheets dir if you make changes since make install overwrites them.
Thanks.
This mail sent through IMP: http://horde.org/imp/
