Re: [Nagios-devel] cisco switches and routers physical port status
> -----Original Message-----
> From: [email protected] [mailto:nagios-devel-
> [email protected]] On Behalf Of rajesh
> Sent: Thursday, August 30, 2007 8:33 AM
> To: [email protected]
> Subject: [Nagios-devel] cisco switches and routers physical port
status
> withnagios
>=20
> Hi Guys,
>=20
> I need to monitor cisco switches and routers physical port status.Can
i
> use check_ifoperstatus plugin or not.One more question my switch port
is
> having 25 or 50 ports how do i check the status.This plugin check all
> interfaces by default or i have to menction each interface.
This was answered on nagios-users. Use 'check_ifoperstatus --help' to
find the plugin's purpose and capabilities. You will need to check
specific ports unless you create an intelligent wrapper for the plugin
or write your own that does the same.
Marc
