Re: [Nagios-devel] Errors while testing Nagios
On 10/23/2010 11:33 AM, Andreas Ericsson wrote:
> On 10/23/2010 12:21 AM, Mathieu Gagné wrote:
>> Tests are both resulting in the same errors and failures.
>> Am I missing libraries or did I miss steps?
> I've moved code around and not catered to Ton's tests when I went on my
> reorganization spree, so it's likely that particular tree is broken wrt
> testing.
> I'll see if I can get around to fixing it today.
Well, lo and behold. Tests run just fine for me now, and I managed to
push the outstanding patches to the public CVS stuff. I even found a
bug I'd introduced thanks to Ton's awesome tests :)
You'll need to force the update if you grab things from git.op5.org
in the future, as cvs syncing causes commit rewrites. I'll make sure
to only push there after I've cvsexported commits, but in case I
forget, make a mental note that it's probably nothing weird going on.
OP5 AB www.op5.se
on peace.
