Gaspar, Carson wrote:
> After sending this I discovered the joy of the new 3.x parameter
> use_large_installation_tweaks...
> Nagios is now eating all 4 of my processors, as requested. I'm not sure
> _why_, as without this setting my server was practically idle...
How many checks are you executing per second to keep a 4 processors
warm? Any details on the hardware you provide us as well? I'm
interested to see how performance is on different systems.
BTW, you can also (as of 3.0b6) disable a new
"enable_environment_macros" option if you don't reference env. vars to
get macro values in your scripts. Its a huge waste of time for most people.
> I'm now seeing about 13.5 checks/sec, much closer to what I expected.
> Of course passive checks are processed at 1052/sec, at why I use them!)
>> -----Original Message-----
>> From: [email protected]
>> [mailto:[email protected]] On Behalf
>> Of Gaspar, Carson
>> Sent: Friday, November 09, 2007 11:47 AM
>> To: '[email protected]'
>> Subject: SPAM WARNING!: [Nagios-devel] Nagios active check
>> performance limits
>> I sent this to -users earlier, but it's probably more
>> appropriate for -devel.
>> FYI I just re-ran my tests with 3.0b6 and am seeing about the
>> same results.
>> (Disclosure - I'm giving an invited talk at LISA next week on Nagios)
>> I'm trying to determine the maximum active check rate that
>> Nagios can sustain on a given system. I'm rather surprised
>> that I can't seem to get more than about 3 checks per second.
>> Am I just being dense? (I haven't used anything but passive
>> checks for years now, so my active check foo is
>> stale...)
>> Nagios config settings (testing with 2.9, which is what we're using in
>> production):
>> service_inter_check_delay_method=0.01 (tried s as well...)
>> service_interleave_factor=s
>> host_inter_check_delay_methos=0.01 (tried s as well)
>> max_concurrent_checks=0
>> service_reaper_frequency=1
>> sleep_time=0.01
>> performance stats show svc execution at 0 / .8 / .459, svc
>> latency at 0 /
>> 10467.99 / 4475.5599 (3 hours after launch, with only 32708 /
>> 50000 services
>> checked)
>> I never see more than 9 nagios procs at once. The config is
>> large (5000 hosts with 10 services each). The service checks
>> are a simple c program that sleeps for half a second then returns OK.
>> Is this really the best Nagios can do, or am I missing something?
>> Carson
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
