Re: [Nagios-devel] Allow event-handler cancelation
On 03/08/2011 10:24 AM, Matthieu Kermagoret wrote:
> Hi list,
> Currently event-handlers can be overriden by NEB modules using the
> NEBERROR_CALLBACKOVERRIDE macro. Attached patch also allo the
> NEBERROR_CALLBACKCANCEL macro to be used to cancel event-handler
> execution.
NEBERROR_CALLBACKCANCEL is used as a one-time measure to cancel
checks, while NEBERROR_CALLBACKOVERRIDE is used to cancel them
without rescheduling them. I'm not sure if we want to muddy the
distinctions by having them mean the same for things that aren't
re-scheduled automagically.
OP5 AB www.op5.se
on peace.
