Re: [Nagios-devel] avail.cgi timerperiods patch
--------------060406000401040303020002
Will this patch be available to 1.2 branch too?
TIA,
SMV
Ethan Galstad wrote:
>Thanks - kudos for cracking this problem. The availability CGI code
>is not that easy to understand.
>On 21 Oct 2004 at 10:35, Michael Medin wrote:
>>Hi,
>>This is a simple patch that allows (or so I hope) availability reports
>>to be made based on a time period. What this means is that I can
>>generate reports for other timeframes then 24x7.
>>We use this internally to generate availability reports for some of
>>our systems that have an 8x5 SLA. How this works and is implemented is
>>that on the last page of the availability report you can select a
>>predefined timeperiod and then only time during that period is counted
>>towards the avalibility report.
>>This means that for our SLA which is 9-5 mon-fri I can generate
>>avalibility reports for that timeframe but still monitor 24x7.
>>As I stated before I don't know that much about nagios development so
>>if this is implemented badly, have bugs or plain out doesn't work
>>please let me know :)
>>BTW; the "patch" has been generated with tortouise so it might
>>possibly not follow whatever standard patches should but I could apply
>>it to my Linux box sp hopefully it will work.
>>// Michael Medin
>Ethan Galstad,
>Nagios Developer
>Email: [email protected]
>Website: http://www.nagios.org
>This SF.net email is sponsored by: IT Product Guide on ITManagersJournal
>Use IT products in your business? Tell us what you think of them. Give us
>Your Opinions, Get Free ThinkGeek Gift Certificates! Click to find out more
>http://productguide.itmanagersjournal.c ... promo.tmpl
>_______________________________________________
>Nagios-devel mailing list
>[email protected]
>https://lists.sourceforge.net/lists/lis ... gios-devel
Content-Type: text/html; charset=ISO-8859-1
TIA,
SMV
// Michael Medin
Ethan Galstad,
Nagios Developer
...[email truncated]...
