to reflect a bit of what I was thinking. Dumping data into a DB
would be handled by an external daemon of some kind.
On 27 Mar 2002 at 20:23, Mark Gillett wrote:
> Thanks for the pointer on the future Ethan, I am not sure how many of the
> Netsaint/Nagios users out here are using the database support, but it seems
> to be a reasonable number. Would you envisage us adding database support as
> a 'patch' or might you consider providing an API against which we could
> implement any other 'storage service' that we might want to play with.
> I guess that the alternative might be for someone
> SQL-->Files bridge (mmmm sounds a bit like mSQL v 0.1) for those who still
> want/need db support.
> Personally I am playing with the database as the files get a little clunky
> when writing other analysis code and or interfaces to monitoring/management
> systems other than Nagios
> are much faster (to code and to perform), especially when log-file rotation
> (archiving) is enabled.
> Where can the community add most value here ?
> Mark
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]]On Behalf Of Ethan
> Galstad
> Sent: Wednesday, March 27, 2002 7:27 PM
> To: [email protected];
> [email protected]
> Subject: Re: [Nagios-devel] MSQL Tables and log files mis-match in data
> types, any ideas
> Thanks for pointing this out. The inconsistencies should be fixed,
> although its not a huge deal. Changing the DB tables at this point
> might be a waste of time, as I plan on dropping native DB support in
> version 2.0.
> On 27 Mar 2002 at 18:32, Mark Gillett wrote:
> > Hi All,
> > I have been investigating linking some of our in-house tools to Nagios and
> > have been working on reading from either the log files or a MySql database
> > for retention and status information.
> > In these explorations I have discovered some 'maybe' inconsistencies in
> the
> > data types used and descriptions of these as below:
> > I may be missing something or might be just straight dumb on this - has
> > anyone else got any ideas ?
> > in
> > TABLE hostretention --->
> > last_check int(11)
> > appears to be a short integer and is described as a time_t since the unix
> > epoch in the log-file documentation,
> > but in
> > TABLE hoststatus --->
> > last_check datetime
> > appears to be a datetime but is still described as a time_t since the
> unix
> > also confusing is that in
> > time_up bigint(20)
> > time_down bigint(20)
> > time_unreachable bigint(20)
> > and are described as no. of seconds elapsed in that state, or since the
> last
> > start of the server, but in
> > time_up int(11)
> > time_down int(11)
> > time_undreachable int(11)
> > which is described as no. of seconds elapsed as well.
> > Am I missing something - does anyone know if there is a reason for this,
> if
> > not should I look at harmonising the database descriptions. Also should
> we
> > think about updating the xdata code to unift the storage between the files
> > and the database in terms of data-types.
> > Also - has anyone written a file to database or database to file
> conversion
> > tool ?
> > Thanks,
> > Mark Gillett
> > IXIF Ltd
> > UK NMS Support
> > _______________________________________________
> > Nagios-devel mailing list
> > [email protected]
> > https://lists.sourceforge.net/lists/lis ... gios-devel
> Ethan Galstad,
> Nagios Developer
> Email: [email protected]
> Website: http://www.nagios.org
> [email protected]
> https://lists.sourceforge.net/lists/listinf
...[email truncated]...
