Re: [Nagios-devel] time_change_threshold is NULL
i also noticed this error, the default value is set to 900 in the sources
but nagios is complaining about that empty setting.
Regards,
Michael
Am 16.10.08 13:16 schrieb "Sven Nierlein" unter :
> Hi,
>=20
> testing the 3.0.4 release revealed the following issue:
>=20
> There is a new config parameter introduced, which has no default value in
> the sample-config/nagios.cfg.in
>> # TIME CHANGE ADJUSTMENT THRESHOLDS
>> # These options determine when Nagios will react to detected changes
>> # in system time (either forward or backwards).
>>=20
>> time_change_threshold=3D
>=20
> which then results in
>> Error in configuration file '.../nagios/nagios.cfg' - Line 1191 (NULL
>> value)
>=20
> Regards,
> Sven
--=20
Michael Streb
Managing Consultant
NETWAYS GmbH | Deutschherrnstr. 15-19 | D-90429 N=FCrnberg
Tel: +49 911 92885-0 | Fax: +49 911 92885-77
GF: Julian Hein | AG N=FCrnberg HRB18461
http://www.netways.de | [email protected]
** NETWAYS Nagios Training - http://www.netways.de/training **
