Re: [Nagios-devel] coredumps
> -----Original Message-----
> From: [email protected] [mailto:nagios-devel-
> [email protected]] On Behalf Of Andrew Ivanov
> Sent: Wednesday, December 05, 2007 6:32 AM
> To: 'Nagios Developers List'
> Subject: Re: [Nagios-devel] coredumps
> Andreas Ericsson wrote:
> > > Can it be that many Nagios community people have to set $HOME to
> > > ~nagios because of no homedir determination?
> > > $HOME points to ~root unless explicitly set, and surely nagios
> can't
> write
> > > there.
> > The point is that when run as root, nagios really shouldn't dump
> core,
> > and especially not if it has read anything in /etc, since the
> coredump
> > can then contain snippets of files best kept for the eyes of root
> only.
> > > And.. I was confused with the fact that '$HOME' is not nagios's
> home.
> > You don't have to start nagios as root. You can do
> > su - nagios -c "nagios -f nagios.cfg"
> > in your startup script.
> I think it's a mistake. Nagios drops privileges if ran by root.
> And there is invocation line from the source example daemon-init
> script:
> $NagiosBin -d $NagiosCfgFile
> there is no 'su' at all. 'su -' is used also, but only in pre-cmd
> phase:
> su - $NagiosUser -c "touch $NagiosVarDir/nagios.log
> $NagiosRetentionFile"
Unrelated to this conversation but this should really be:
touch $NagiosVarDir/nagios.log $NagiosRetentionFile
chown $NagiosUser:$NagiosGroup $NagiosVarDir/nagios.log $NagiosRetentionFile
Otherwise the nagios user needs a shell other than /sbin/nologin
> I use similar script and can see that all Nagios processes are owned by
> user
> nagios,
> but HOME=/root (as expected)!
> > > I just wanted to make things a little easier to configure.
> > In that case, make it a config variable in nagios.cfg. Something
> along
> > the lines of "runtime_directory" or something should work ok, and
> make
> > nagios bail if it can't change to that directory when daemonizing. It
> > doesn't change directory at all unless it goes into daemon mode.
> It will be so strange to have one more variable for cores.
> There is code from base/util.c:
> /* change working directory. scuttle home if we're dumping core
> homedir=getenv("HOME");
> if(daemon_dumps_core==TRUE && homedir!=NULL)
> chdir(homedir);
> else
> chdir("/");
> Keeping in mind example above (HOME==/root), one might conclude that
> code
> is inconsistent, and will never work without manual intervention.
> > Andreas Ericsson [email protected]
> > OP5 AB www.op5.se
> > Tel: +46 8-230225 Fax: +46 8-230231
> With best regards,
> Andrew.
> SF.Net email is sponsored by: The Future of Linux Business White Paper
> from Novell. From the desktop to the data center, Linux is going
> mainstream. Let it simplify your IT future.
> http://altfarm.mediaplex.com/ad/ck/8857-50307-18918-4
> Nagios-devel mailing list
> [email protected]
