Re: [Nagios-devel] Possible bug in timeperiod parsing
--_000_F2969C1B08CBEE42B78C04C280D578E72CA2100578donkeylandcar_
Content-Type: text/plain; charset="us-ascii"
On Tue, 2008-12-16 10:44:14 GMT, matthias eble wrote:
> In general, this should work. Which Nagios version are you using?
> If you're using Nagios 3: Have you tried to set up debugging for
> notifications in nagios.cfg?
You are correct, it should work, but it is ignoring the time periods for SM=
S messages, i.e. they go out 24x7.
I'm using Nagios 3.0.6. I enabled debugging with verbosity set to level 2,=
and when a recovery notification went out, the log looks like this (edited=
a bit)
[1229456867.888599] [032.0] [pid=3D27002] ** Host Notification Attempt ** H=
ost: 'server', Type: 0, Options: 0, Current State:
0, Last Notification: Thu Jan 1 12:00:00 1970
[1229456867.888699] [032.0] [pid=3D27002] Notification viability test passe=
d.
[1229456867.888738] [032.1] [pid=3D27002] Current notification number: 2 (i=
ncremented)
[1229456867.888762] [032.2] [pid=3D27002] Creating list of contacts to be n=
otified.
[1229456867.888845] [032.1] [pid=3D27002] Host notification will NOT be esc=
alated.
[1229456867.888887] [032.1] [pid=3D27002] Adding normal contacts for host t=
o notification list.
[1229456867.888914] [032.2] [pid=3D27002] Adding individual contacts for ho=
st to notification list.
[1229456867.888933] [032.2] [pid=3D27002] Adding members of contact groups =
for host to notification list.
[1229456867.888947] [032.2] [pid=3D27002] Adding members of contact group '=
server-admins' for host to notification list.
[1229456867.888963] [032.2] [pid=3D27002] Adding contact 'bob' to notificat=
ion list.
[1229456867.889005] [032.2] [pid=3D27002] Adding contact 'bill' to notific=
ation list.
[1229456867.889128] [032.2] [pid=3D27002] Adding contact 'bobysms' to noti=
fication list.
[1229456867.889150] [032.2] [pid=3D27002] Adding contact 'billbysms' to not=
ification list.
[1229456867.889234] [032.2] [pid=3D27002] ** Attempting to notifying conta=
ct 'bobbysms'...
[1229456867.889256] [032.2] [pid=3D27002] ** Checking host notification via=
bility for contact 'bobbysms'...
[1229456867.889399] [032.2] [pid=3D27002] ** Host notification viability fo=
r contact 'bobbysms' PASSED.
[1229456867.889431] [032.2] [pid=3D27002] ** Notifying contact 'bobbysms'
[1229456867.889474] [032.2] [pid=3D27002] Raw notification command: /usr/bi=
n/printf "Type: $NOTIFICATIONTYPE$\nHst: $HOSTNAME
$\nS: $HOSTSTATE$\nIP: $HOSTADDRESS$\nSvc: $SERVICEDESC$\nS: $SERVICESTATE$=
\nI: $HOSTOUTPUT$\nDate/Time: $SHORTDATETIME$\n"
| /usr/bin/sendsms.pl $CONTACTPAGER$
[1229456867.923656] [032.2] [pid=3D27002] Processed notification command: /=
usr/bin/printf "Type: RECOVERY\nHst: server\nS: UP
\nIP: 202.27.240.1\nSvc: $SERVICEDESC$\nS: $SERVICESTATE$\nI: PING OK - Pac=
ket loss =3D 0%, RTA =3D 0.24 ms\nDate/Time: 12-17-2
008 08:47:47\n" | /usr/bin/sendsms.pl 0123456789
[1229456868.676251] [032.2] [pid=3D27002] Calculating next valid notificati=
on time...
[1229456868.676330] [032.2] [pid=3D27002] Default interval: 0.000000
[1229456868.676370] [032.2] [pid=3D27002] Interval used for calculating nex=
t valid notification time: 0.000000
[1229456868.676424] [032.0] [pid=3D27002] 4 contacts were notified. Next p=
ossible notification time: Wed Dec 17 08:47:47 20
08
[1229456868.676447] [032.0] [pid=3D27002] 4 contacts were notified.
Nothing there about why the sms contacts were added. One thing that is a b=
it strange is the last notification date of 1970. The time on the box is c=
orrect:
# date
Wed Dec 17 09:07:59 NZDT 2008
So still no idea why SMS notifications are going out.
________________________________
Please consider the environment before printing this email
Warning: This electronic message together with any attachments is confident=
ial. If you receive it in error: (i) you must not read, use, disclose, copy=
or retain it; (ii) please contact the sender immediately by reply email an=
d then delete the emails.
The views expressed in this email may not be those of Landcare Research N
...[email truncated]...
