Re: [Nagios-devel] [Nagios-users] Nagios client merge NSCA/NRPE
Hans Engelen wrote:
> On the Nagios side I am currently using a fairly simple perl script
> (currently cronned) that feeds back into the external command file
> though I might go with an actual module that hooks into the nagios
> process later if the need arises (although I don't really want to if I
> can help it).
The nagios command file has very little overhead associated with it.
You will almost definitely not need to write a module for that reason.
OP5 AB www.op5.se
