[Nagios-devel] [core] config file parsing: check end of definition
--wac7ysb48OaltWcw
Content-Type: text/plain; charset*=utf-8''%E2%80%9Cus-ascii
Content-Disposition: inline
Attached patch fixes some unreachable code for detecting the end of a 'define'.
Currently there are two check for it right after each other. The first one can
be removed...
-Marcel
======-------- Marcel J.E. Mol MESA Consulting B.V.
=======--------- ph. +31-(0)6-54724868 P.O. Box 112
=======--------- [email protected] 2630 AC Nootdorp
__==== www.mesa.nl ---____U_n_i_x______I_n_t_e_r_n_e_t____ The Netherlands ____
They couldn't think of a number, Linux user 1148 -- counter.li.org
so they gave me a name! -- Rupert Hine -- www.ruperthine.com
--wac7ysb48OaltWcw
Content-Disposition: attachment; filename="xodtemplate.dif"
--- org/nagios-HEAD/xdata/xodtemplate.c 2010-03-29 16:51:38.000000000 +0200
+++ nagios-HEAD/xdata/xodtemplate.c 2010-10-14 19:50:18.681571847 +0200
@@ -755,21 +755,6 @@
in_definition=TRUE;
- /* this is the close of an object definition */
- else if(!strcmp(input,"}") && in_definition==TRUE){
- in_definition=FALSE;
- /* close out current definition */
- if(xodtemplate_end_object_definition(options)==ERROR){
-#ifdef NSCORE
- logit(NSLOG_CONFIG_ERROR,TRUE,"Error: Could not complete object definition in file '%s' on line %d.\n",filename,current_line);
-#endif
- result=ERROR;
- break;
/* we're currently inside an object definition */
else if(in_definition==TRUE){
--wac7ysb48OaltWcw--
