Re: [Nagios-devel] bug: unlocking an invalid mutex
Geert Hendrickx wrote:
> Hi,
> I tried to upgrade a Nagios 2.5 system running on NetBSD to Nagios 2.9.
> But it seems like a mutex bug has been introduced in Nagios 2.7 (I can
> reproduce it with Nagios 2.7 but not with 2.5 and 2.6).
> Unlike Linux, NetBSD's pthread implementation is quite unforgiving for
> mutex errors, and aborts a running program e.g. when it tries to unlock
> an invalid mutex. This is what is happening with Nagios:
>> Nagios 2.9 starting... (PID=17620)
>> nagios: Error detected by libpthread: Invalid mutex.
>> Detected by file "/cvs/src/3/lib/libpthread/pthread_mutex.c", line 334, function "pthread_mutex_unlock".
>> See pthread(3) for information.
>> Program received signal SIGABRT, Aborted.
>> [Switching to LWP 1]
>> 0xbd9e921f in kill () from /usr/lib/libc.so.12
>> (gdb) bt
>> #0 0xbd9e921f in kill () from /usr/lib/libc.so.12
>> #1 0xbdaa6fb6 in pthread__errorfunc () from /usr/lib/libpthread.so.0
>> #2 0xbdaa3d4b in pthread_mutex_unlock () from /usr/lib/libpthread.so.0
>> #3 0x080a1651 in xsddefault_save_status_data () at ../xdata/xsddefault.c:338
>> #4 0x080a10bd in update_all_status_data () at ../common/statusdata.c:93
>> #5 0x080544dc in main (argc=2, argv=0xbfbfe8b8, env=0xbfbfe8c4) at nagios.c:665
>> #6 0x0805377d in ___start ()
>> (gdb)
> The problem is probably in this change between Nagios 2.6 and 2.7:
> --- xdata/xsddefault.c 2006-05-20 21:39:34.000000000 +0200
> +++ xdata/xsddefault.c 2007-01-03 03:50:43.000000000 +0100
> @@ -322,6 +331,18 @@
> return ERROR;
> + /* get number of items in the check result buffer */
> + pthread_mutex_lock(&service_result_buffer.buffer_lock);
> + used_check_result_buffer_slots=service_result_buffer.items;
> + high_check_result_buffer_slots=service_result_buffer.high;
> + pthread_mutex_unlock(&service_result_buffer.buffer_lock);
> + /* get number of items in the command buffer */
> + pthread_mutex_lock(&external_command_buffer.buffer_lock);
> + used_external_command_buffer_slots=external_command_buffer.items;
> + high_external_command_buffer_slots=external_command_buffer.high;
> + pthread_mutex_unlock(&external_command_buffer.buffer_lock);
> /* write version info to status file */
> fprintf(fp,"########################################\n");
> fprintf(fp,"# NAGIOS STATUS FILE\n");
> Can this please be looked into? Do I need to provide more information?
I suppose just checking for success from the pthread_mutex_lock() calls would
be enough, and letting it spinlock for 10 tries if it fails. If it *always* fails,
that would be quite horrible though, as it would mean something fairly illegal is
going on in there.
I'll whip up a patch for it once I'm done with what I'm currently fiddling with.
OP5 AB www.op5.se
