RE: [Nagios-devel] More Nagios bugs (minor)
Good day,
Just try this out (the circular diagram with multiple parents), and you'll
see why this is actually a bug.
To better describe in words: imagine that I have a parent X, and host
children A through G. On the diagram, A through G will appear in a fan
arrangement around X. Now, imagine that I add another parent to children B
through F, such that they now appear fanned out from a different parent.
One would expect that hosts A and G would appear together now in the
diagram, but instead they appear in the same locations they did before, with
a lot of empty space between them where B and F used to be.
It's a bit hard to describe, but if you try it out yourself, you'll see
exactly what I mean.
Thanks again. I'll be sure to let you guys know if there is anything else
that I come across. =)
Darren Gamble
Planner, Regional Services
Shaw Cablesystems GP
630 - 3rd Avenue SW
Calgary, Alberta, Canada
T2P 4L4
(403) 781-4948
> -----Original Message-----
> From: Ethan Galstad [mailto:[email protected]]
> Sent: Wednesday, May 22, 2002 8:40 PM
> To: [email protected]
> Subject: Re: [Nagios-devel] More Nagios bugs (minor)
> On 22 May 2002 at 12:01, Darren Gamble wrote:
> > Good day,
> > I've had some more time to work with Nagios. So far, so
> good. =) I've also
> > downloaded the CVS version and made RPMs from it.
> > Just a few minor display bugs to report:
> > - The "circular" display formats don't properly display
> hosts that have more
> > than one parent. It "picks" one of the parents and places
> the host in the
> > circle near it (which is fine), but it leaves an "empty"
> space outside of
> > the circle of the other parent. This is easiest to see
> with the "Circular -
> > Marked up" diagram, which has empty green blocks where the
> host would
> > normally appear if it didn't have the other parent.
> Essentially, there is
> > wasted space.
> Not really a bug, just undesirable behavior. Every layout method
> seems to the have some problem or another. The circular layout
> method was modelled after the description of how the gnutellavision
> app worked. I haven't found any good algorithms for doing optimal
> layout and no one has ever (as far as I recall) even provided me with
> pseudocode for a better layout method, so I've only been able to
> implement things in hackish ways.
> > - Clicking twice on a host brings up its services, which works fine.
> > However, the "x Matching Service Entries Displayed" summary
> displays the
> > number of ALL of the hosts that Nagios is monitoring, not
> the number of the
> > services for the host. Not sure if this appears for other
> queries, but,
> > that's the one that I've noticed.
> Thanks for the report. Should be fixed in CVS now.
> Ethan Galstad,
> Nagios Developer
> Email: [email protected]
> Website: http://www.nagios.org
> _______________________________________________________________
> Don't miss the 2002 Sprint PCS Application Developer's Conference
> August 25-28 in Las Vegas -- http://devcon.sprintpcs.com/adp/index.cfm
> Nagios-devel mailing list
> [email protected]
