Re: [Nagios-devel] [patch] Fix invalid DOM in CGI
On 12/09/2011 03:23 PM, Sven-Göran Bergh wrote:
> Attached patch fixes an invalid DOM.
> A table element may not have a form
> element as a direct child, but the
> opposite is OK.
> The forms become invalid in some browsers
> when the CGI:s are AJAX loaded in div
> element.
Neat patch, but why not start the table directly after the form?
That way it would have been obvious that the patch doesn't change
the layout. Now it's split so I can't say for sure that it
doesn't without having to look at the code, and I won't have
time to do that until next week. Care to reroll and resend a
more easily reviewed patch?
Thanks.
OP5 AB www.op5.se
on peace.
