2009/9/7 Hiren Patel :
>>>> Versions:
>>>> check_nrpe (from openSUSE Build Service)
>>>> NRPE Plugin for Nagios
>>>> Copyright (c) 1999-2008 Ethan Galstad ([email protected])
>>>> Version: 2.12
>>>> Last Modified: 03-10-2008
>>>> License: GPL v2 with exemptions (-l for more info)
>>>> SSL/TLS Available: Anonymous DH Mode, OpenSSL 0.9.6 or higher required
>>>> remote NRPE agent (compiled from source)
>>>> spmon:~ # /usr/lib/nagios/plugins/check_nrpe -H solaris
>>>> NRPE v2.12
>>>> Any ideas?, I have a truss capture of the daemon from a working
>>>> execution and a non-working execution if anyone would like to check
>>>> them (don't know if attachments are allowed)
>> Debug is ON already, but all I get in the logs is the start/stop process=
>> Sep =C2=A07 11:55:48 billbd2 nrpe[11796]: [ID 678021 daemon.notice] Caug=
ht
>> SIGTERM - shutting down...
>> Sep =C2=A07 11:55:48 billbd2 nrpe[11796]: [ID 915785 daemon.error] Canno=
t
>> remove pidfile '/var/run/nrpe.pid' - check your privileges.
>> Sep =C2=A07 11:55:48 billbd2 nrpe[11796]: [ID 938771 daemon.notice] Daem=
on shutdown
>> Sep =C2=A07 11:55:52 billbd2 nrpe[23649]: [ID 601491 daemon.notice]
>> Starting up daemon
>> Sep =C2=A07 11:55:53 billbd2 nrpe[23649]: [ID 627629 daemon.notice]
>> Warning: Daemon is configured to accept command arguments from
>> clients!
> you have debug=3D1 in your config file? you ran the remote nrpe checks
> after restarted in debug mode? it should print the command requested and
Yes
> the results of running the command.
I don't see that either in the check_nrpe end or on the server logs.
> you're running the 2.12 nrpe server right?
Yes
> how did you install the nrpe server on solaris, packages or compiled?
Compiled.
--=20
Ciro Iriarte
http://cyruspy.wordpress.com
