Re: [Nagios-devel] [PATCH] AIX - fix for xlc compile warnings due
Markus Baertschi wrote:
> On AIX the xlc compiler generates two warnings for each source file
> because the RTLD_ macros are defined before is included.
> This patch moves the definitions to after the include.
> The patch applies against 3.0.3 and the CVS tarball. I've tested
> it on AIX 5.3 with xlc (the IBM compiler) and gcc and also on
> Linux (Ubuntu hardy, gcc 4.1.2).
> Markus
Thanks!
- Ethan Galstad
