> For the first two - I think the numbers were put in such that a decent
> default would exist for new users. It is meant to ease them into using
> and understanding the config files.
OK, that's reasonable. Then should it be modified as like this?
Index: services.cfg.in
RCS file: /cvsroot/nagios/nagios/sample-config/template-object/services.cfg.in,v
retrieving revision 1.2
diff -u -r1.2 services.cfg.in
--- services.cfg.in 10 Mar 2002 23:49:27 -0000 1.2
+++ services.cfg.in 8 Jun 2002 06:09:38 -0000
@@ -107,7 +107,7 @@
notification_interval 120
notification_period 24x7
notification_options c,r
- check_command check_ping!100.0,20%!500.0,60%
+ check_command check_ping
@@ -183,7 +183,7 @@
@@ -202,7 +202,7 @@
@@ -259,7 +259,7 @@
@@ -316,7 +316,7 @@
notification_interval 240
@@ -430,7 +430,7 @@
@@ -544,7 +544,7 @@
@@ -563,7 +563,7 @@
@@ -582,7 +582,7 @@
@@ -601,7 +601,7 @@
@@ -620,7 +620,7 @@
@@ -639,7 +639,7 @@
@@ -677,7 +677,7 @@
notification_interval 960
notification_period workhours
@@ -714,7 +714,7 @@
@@ -751,7 +751,7 @@
Jun Kuriyama // IMG SRC, Inc.
// FreeBSD Project
