Why would you think it did?
Since we assumed that check output was escaped, we tried to unescape
it, and that becomes highly weird.
So, this bug meant that, unless a command is quoted (which, as shown in
the parent commit, you couldn't do), if you're trying to test quoting by
writing a check command that echoes your input, you needed four
backslashes in your input to get one in your output. Trying to read the
quad-escaped commands in the input, in turn, quickly makes a user want
to escape from this application.
Signed-off-by: Robin Sonefors
base/checks.c | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/base/checks.c b/base/checks.c
index b534bd4..c8e8726 100644
--- a/base/checks.c
+++ b/base/checks.c
@@ -442,7 +442,7 @@ int handle_async_service_check_result(service *temp_service, check_result *queue
else {
/* parse check output to get: (1) short output, (2) long output, (3) perf data */
- parse_check_output(queued_check_result->output, &temp_service->plugin_output, &temp_service->long_plugin_output, &temp_service->perf_data, TRUE, TRUE);
+ parse_check_output(queued_check_result->output, &temp_service->plugin_output, &temp_service->long_plugin_output, &temp_service->perf_data, TRUE, FALSE);
/* make sure the plugin output isn't null */
if(temp_service->plugin_output == NULL)
@@ -2160,7 +2160,7 @@ int execute_sync_host_check(host *hst) {
hst->check_type = CHECK_TYPE_ACTIVE;
/* parse the output: short and long output, and perf data */
- parse_check_output(temp_plugin_output, &hst->plugin_output, &hst->long_plugin_output, &hst->perf_data, TRUE, TRUE);
+ parse_check_output(temp_plugin_output, &hst->plugin_output, &hst->long_plugin_output, &hst->perf_data, TRUE, FALSE);
/* free memory */
my_free(temp_plugin_output);
@@ -2545,7 +2545,7 @@ int handle_async_host_check_result(host *temp_host, check_result *queued_check_r
my_free(temp_host->perf_data);
- parse_check_output(queued_check_result->output, &temp_host->plugin_output, &temp_host->long_plugin_output, &temp_host->perf_data, TRUE, TRUE);
+ parse_check_output(queued_check_result->output, &temp_host->plugin_output, &temp_host->long_plugin_output, &temp_host->perf_data, TRUE, FALSE);
/* make sure we have some data */
if(temp_host->plugin_output == NULL || !strcmp(temp_host->plugin_output, "")) {
1.7.11.7
