Re: [Nagios-devel] Nagios 3.3.1 is not processing performance data
Rodney Ramos wrote:
> Hi, everybody.
> I´ve installed Nagios 3.3.1 and noticed that it is not processing
> performance data when it is null.
> This is a big problem for me, because I use the performance process to
> send data to my central servers, instead of de ocsp command, as this
> command makes the latency increase a lot.
> When I made the downgrade to Nagios 3.2.3 everything works fine.
> Can someone help me? Was the Nagios Core code modified? I didn´t find
> anything on the release change log.
there was a discussion recently on the lists, look for
[Nagios-users] empty perfdata not put on perfdata channels anymore in 3.3.1
[Nagios-users] perfdata-file not working the same since upgrade from
3.0.2 to 3.3.1
http://www.mail-archive.com/nagios-user ... 36537.html
http://comments.gmane.org/gmane.network ... devel/8128
and the according bug tracker item is
http://tracker.nagios.org/view.php?id=252
http://tracker.nagios.org/view.php?id=247
if you want to read a deeper analysis
https://dev.icinga.org/issues/1413
and a workaround fix for nagios, which i did when fixing this
misbheaviour in icinga some months ago, can be found here (use at your
own risk)
https://github.com/dnsmichi/nagios-fixe ... 39e9e81de0
if not, i suggest downgrading to 3.2.3 and wait for a proper release
containing a fix.
hth
michael
DI (FH) Michael Friedrich
Vienna University Computer Center
Universitaetsstrasse 7 A-1010 Vienna, Austria
email: [email protected]
phone: +43 1 4277 14359
mobile: +43 664 60277 14359
fax: +43 1 4277 14338
web: http://www.univie.ac.at/zid
http://www.aco.net
Lead Icinga Core Developer
http://www.icinga.org
