[Nagios-devel] Database / Log File Formats Continued
I am continuing to work through the log files for Nagios, while there is
some documentation at :
http://www.netsaint.org/docs/0_0_7/deve ... sfile.html
for the statusfile, there does not appear to be the same for Nagios.
I took a look at my Nagios output and there appear to be two additional
'fields' in the Nagios file (host entries) over the Netsaint one ....
Does anyone know the format for the Nagios file - Ethan, if you have the
e.g.
Host Status Format:
[] HOST;
etc handy .... I would be happy to check it and to update the Netsaint
documents for Nagios ....
Mark
