[Nagios-devel] Nagios 4 on Solaris 10
Hi!
Has anyone tried the latest Nagios 4 code on Solaris 10?=20
We get "(Service check did not exit properly)" for every active check =
result. It looks to me like the worker process code has something which =
is not working in Solaris. I think the communication is okay.
There is a lib/wproc which looks like a worker test executable, which =
executes commands from stdin via the worker process. This seems to =
execute on the Solaris worker process and gets the output and errors, =
but doesn't finish correctly.
The simplest reproduction is to use the worker test executable. cd lib =
&& make wproc. This will fail with some missing symbols. Compile by =
adding '-lsocket -lnsl' to the compiler flags. Run ./wproc and enter =
'hostname'. This will timeout before returning the result.
Any ideas? Any Solaris users?
Ton
