[Nagios-devel] CVS nrpe_check 'result' fix
It was bugging me that nrpe_check.c was not picking up the
correct result code, giving me "GREEN" when load was
WARNING or CRITICAL on nrpe machines.
Debug log showed nrpe plugin was sending out a correct
result code. However running nrpe_check from the command
line to the same host and looking [echo $?] at the return
status showed that nrpe_check was not getting the correct
result.
Comparing nrpe and nrpe_check CVS sources from a day or two
ago shows that the nrpe.d does [correctly] htons to get the
int16_t packet_struct::result value.
But nrpe.c was using ntohl... oops! (at least for the
endianness on my i686 box) ... it got truncated to zero!
(The essential fix is a one-liner, so no diff just change the line)
nrpe-2.0a1/src/check_nrpe.c
/* get the return code from the remote plugin */
/* result=(int16_t)ntohl(receive_packet.result_code); orig */
result=(int16_t)ntohs(receive_packet.result_code); /*[ejk]*/
/* [ejk] should also check ..packet.packet_version
* and ..packet.packet_type for correctness/paranoia ?? */
Now check_nrpe shows yellow for WARNINGS, at least for me.
Please CC me directly if this seems acceptable as I'm not on the lists
Erik ([email protected])
