Message en plusieurs parties au format MIME
--=_related 0043F8F9C1257809_=
Content-Type: multipart/alternative;
boundary="=_alternative 0043F900C1257809_="
--=_alternative 0043F900C1257809_=
Content-Type: text/plain; charset="ISO-8859-1"
Thanks for your reply.
I used a prefix in 'configure' to change my path :
./configure --prefix=3D/hawai/composants/nagios --with-gd-inc=3D/usr/includ=
e=20
--with-gd-lib=3D/usr/lib --with-command-group=3Dnagios
make all -j 4
make install
make install-init
make install-commandmode
make install-config
make install-daemoninit
But I don't understand why you have a nagios3 daemon. Into the Makefile I =
have :
install-daemoninit:
$(INSTALL) -m 755 -d $(INIT=5FOPTS) $(DESTDIR)$(INIT=5FDIR)
$(INSTALL) -m 755 $(INIT=5FOPTS) daemon-init=20
$(DESTDIR)$(INIT=5FDIR)/nagios
I could not find a string like 'nagios3Waiting for nagios3 daemon to=20
die.................' into the daemon-init file.
What's wrong ?
Pierre
Pierre SMOROWINSKI
Ing=E9nieur Infrastructures Syst=E8mes & Composants
P=F4le National de R=E9novation
[email protected]
T=E9l. :
04 93 95 55 60
CNIR SUD - BP 215 - 06904 SOPHIA ANTIPOLIS CEDEX
Contribuons au respect de l'environnement, n'imprimez ce courriel qu'en=20
cas de n=E9cessit=E9 et ayez le r=E9flexe recto-verso=20
Alexander Wirt =20
30/12/2010 12:55
A
Pierre SMOROWINSKI
cc
Nagios Developers List
Objet
Re: [Nagios-devel] Wrong status in init.d/nagios when nagios is stopped
Pierre SMOROWINSKI schrieb am Thursday, den 30. December 2010:
Hi,=20
> I use Nagios 3.2.3, it works prefectly.
>=20
> If I stop Nagios :=20
> [root@***]# service nagios stop -> OK
>=20
> and I check the status :
> [root@***]# service nagios status
> No lock file found in /hawai/composants/nagios/var/nagios.lock
hu?=20
This path has noting to do with our packages. Also the service would be
nagios3, not nagios.=20
root@smithers:/etc/init.d# service nagios3 stop
Stopping nagios3 monitoring daemon: nagios3Waiting for nagios3 daemon to
root@smithers:/etc/init.d# service nagios3 status
checking /usr/sbin/nagios3...failed (not running).
root@smithers:/etc/init.d# service nagios3 start
Starting nagios3 monitoring daemon: nagios3.
checking /usr/sbin/nagios3...done (running).
root@smithers:/etc/init.d#=20
Alex
Content-Type: text/html; charset="ISO-8859-1"
I used a prefix in 'configure' to ch=
ange
my path :
--with-gd-inc=3D/usr/include --with-gd-lib=3D/usr/lib --with-command-group=
=3Dnagios
make all -j 4
make install
make install-init
make install-config
have a nagios3 daemon. Into the Makefile I have :
install-daemoninit:
$(INSTAL=
L)
$(INSTAL=
L)
-m 755 $(INIT=5FOPTS) daemon-init $(DESTDIR)$(INIT=5FDIR)/nagios
for nagios3 daemon to die............
...[email truncated]...
