Hello list! I'm working on a new install and cannot seem to get ndoutils
1.b4 or cvs snapshot to work with 3.0b1. Both compiles error with:
[1187881208] ndomod: NDOMOD 1.4b4 (06-19-2007) Copyright (c) 2005-2007
Ethan Galstad ([email protected])
[1187881208] ndomod: I've been compiled with support for revision 303 of
the internal Nagios object structures, but the Nagios daemon is c
urrently using revision 304. I'm going to unload so I don't cause any
problems...
[1187881208] Error: Function nebmodule_init() in module
'/usr/local/nagios/bin/ndomod-3x.o' returned an error. Module will be
unloaded.
[1187881208] Event broker module '/usr/local/nagios/bin/ndomod-3x.o'
deinitialized successfully.
I found an earlier post to this list indicating that this would be
addressed in a later ndoutils release, but cannot seem to find that
codebase. Is there a recommended workaround at this point, or just
disable ndoutils for the time being?
Cvs version of 3.0b2 perhaps fixes this accordign to the changelog?=20
* Internal data structure cleanups
Thanks in advance!
-Matthew
