------=_NextPart_000_0005_01C3A3F3.8BE077B0
Content-Type: text/plain;
charset="us-ascii"
Overview
Add to Nagios notify commands the capability to send HTML email messages
with url encoded hostnames and servicedescs.
This patch makes possible to send HTML notifications with clickable =
dynamic
links to quickly access the pages with details about the problem Nagios =
is
reporting.=20
Very useful for large installations or smart help desks
You can find a screenshot as attachment where it is shown the final=20
result from user point of view. The four links in the screenshot will=20
point to the appropriate pages.
Patch it
To make all of this working you have to:
1) Apply the patch
=20
cd /base
patch utils.c /htmlmail.diff
make;strip nagios;cp nagios /bin
=20
Now set /bin/nagios permissions as those of =
the
other files in that dir and you have finished.
2) Replace the commands in the attached misccommands.cfg with the same
commands in your misccommands.cfg and replace the http://nagiosbox =
string
with the one identifying your Nagios server. I've used sendmail to send
emails but you can replace the "/usr/sbin/sendmail -t" command with your
favorite mailer.
Note for NAGAT users: the edit textarea to change misccommands.cfg =
entries
is stripping "\" characters. Beware of this and edit this file by hand
rather than with Nagat or you will not receive any email. I'm not aware =
of
problems with other web interfaces because I've not tested them. I =
suggest
you to edit this file by hand.
You'll note that there are two new fields that Nagios does not provide:
$ENCODEDHOSTNAME$ and $ENCODEDSERVICEDESC$.
The patch code adds the two new fields to those available in Nagios.
3) Restart Nagios by issuing a STOP and a START command (not RELOAD).
Wait for the next emails and enjoy
Nagios it (for Ethan)
I think this would be a good cosmetic feature for notifications in =
Nagios
v2.0.
I'm sorry but I had no time to implement it against v2.0 CVS, I hope =
this is
not a problem to merge this code into 2.0.
=20
FINAL NOTE: The only annoying thing to care about is that images are not
displayed properly if you have implemented secure access to Nagios site =
and
you are not logged in before reading the email. If you don't care about =
this
I suggest you to strip images from the email code.
Stefano Coletta
http://www.mindcreations.com=20
Content-Type: application/octet-stream;
name="htmlmail.diff"
filename="htmlmail.diff"
212a213,267=0A=
> /* Function imported from cgi/cgiutils.c */=0A=
> /* Added by Stefano Coletta (aka Creator) http://www.mindcreations.com =
on 05/11/2003 */=0A=
> =0A=
> /* encodes a string in proper URL format */=0A=
> =0A=
> char encoded_url_string[MAX_INPUT_BUFFER];=0A=
> =0A=
> char * url_encode(char *input){=0A=
> int len,output_len;=0A=
> int x,y;=0A=
> char temp_expansion[4];=0A=
> =0A=
> len=3D(int)strlen(input);=0A=
> output_len=3D(int)sizeof(encoded_url_string);=0A=
> =0A=
> encoded_url_string[0]=3D'\x0';=0A=
> =0A=
> for(x=3D0,y=3D0;x =0A=
> /* end of string */=0A=
> if((char)input[x]=3D=3D(char)'\x0'){=0A=
> encoded_url_string[y]=3D'\x0';=0A=
> break;=0A=
> }=0A=
> =0A=
> /* alpha-numeric characters don't get encoded */=0A=
> else if(((char)input[x]>=3D'0' && =
(char)input[x]=3D'A' && =
(char)input[x] [x]>=3D(char)'a' && (char)input[x] encoded_url_string[y]=3Dinput[x];=0A=
...[email truncated]...
