Re: [Nagios-devel] [PATCH] circular dependency check speedup
I'd appreciate if you could send new threads as new messages
instead of as replies to current threads. Especially when you're
sending patches. If I hadn't been interested in the topic listed
in this thread, I'd have missed this patch and it had been dropped
on the floor (unless Ton had applied it, in which case I would
have reverted parts of it quite promptly).
I've done some organoleptic analysis of the patch (looked at it).
Analysis included below.
On 12/15/2010 06:38 PM, Glenn Herteg wrote:
> Nagios has historically used a very inefficient algorithm to check
> for circular host and service dependencies, with respect to both
> execution and notification dependencies. This area has been the
> subject of previous patches to improve performance. For example,
> in early 2008, a depth-first-search algorithm was proposed for
> part of this checking, and it was eventually incorporated into
> the standard code base. However, that only affected part of the
> circular-dependency-check algorithm, and performance against tens
> of thousands of dependencies has still been extremely slow (taking
> tens of minutes for a very large configuration).
Neat. So far so good :)
> GroundWork Open Source has looked at this problem with an eye
> toward full optimization, and hereby provides a patch to fix
> the remaining sources of poor performance. The changes here are
> not just theoretical; they have been tested against a very large
> customer configuration, both with and without seeding a number of
> actual circular dependencies, to demonstrate that the same errors
> are caught as with the original code.
If you could make the test configs available online, that'd be
great. I'd like to test this myself.
> The replacement algorithm in
> this patch provides a speedup of around 20,000x for that portion of
> a pre-flight or reload operation, for a configuration with a very
> large number of host or service dependencies. This translates to
> an overall speedup of about 275x with our large test dataset, for
> a complete preflight operation. In simpler terms, many minutes of
> computation dissolve away into just a few seconds.
I'd like numbers, along with architectures this was tested on. Also
the test-configs that were used to get these numbers. Take a look
at a6e06d8de24ffcb4a8c341a60098042dc3284756 to get an idea of how I
like to see performance numbers. The repo where a6e06d8de24ff is
available can be cloned from git://git.op5.org/nagios.git
> Given the timing improvements just noted, it is GroundWork's belief
> that application of this patch will completely obsolete the nagios
> -x and --dont-verify-paths ("Don't check for circular object paths")
> options.
If what you're claiming is true, they'll be deprecated and will do
nothing, but will remain valid options until Nagios 4.x hits the
market.
> The replacement algorithm works in three ways: by using substitute
> data structures which can be operated on much more efficiently, by
> sidestepping huge amounts of pointless work, and by optimizing the
> placement of fields within certain existing data structures so that
> more efficient assembly code is generated for the most commonly used
> field accesses. All of the modifications have been carefully tested
> using actual measurements to show that they do improve execution
> time, so the field-placement changes (for instance) are not based
> on capricious guesswork.
Hmm. Having taken a look at the field restructures, I'll have to say
that your claim is completely bogus for any architecture where
sizeof(int) == sizeof(void *)
which holds true for most architectures not running in compatibility
mode. This is ofcourse only true if the compiler is clever enough to
calculate the real address of the desired variable rather than doing
the memory fetch in two steps, which has been the case for gcc since
1.x sometime. If sizeof(int) != sizeof(void *) and the architecture
brings penalties when doing unaligned memory access, the structure
reordering makes sense, but it would make *more* sense to utilize
a padding scheme for the int thin
...[email truncated]...
