Duplicate definitions after upgrading to 1.3G
hdiadmins
Post by hdiadmins »
Hi there,
I'm getting an error after upgrading to Nagios XI latest version.
Whenever I try to update some service or host it didn't complete. I checked the logs and it says:
'xi_timeperiod_24x7' (config file '/usr/local/nagios/etc/timeperiods.cfg', starting on line 185)
Error: Could not add object property in file '/usr/local/nagios/etc/timeperiods.cfg' on line 186.
Tried to check the config files in CCM and it returns the same thing.
Warning: Duplicate definition found for timeperiod 'xi_timeperiod_24x7' (config file '/usr/local/nagios/etc/timeperiods.cfg', starting on line 185)
So, I opened the file using VI in CentOS and it does not contain duplicate entry and it does not show me a duplicate entry in Web Interface too.
The file's permissions are ok too.
mguthrie
Re: Duplicate definitions after upgrading to 1.3G
Post by mguthrie »
Check your timeperiod definitions in the CCM to make sure there isn't a duplicate that got generated somehow (or cloned).
You could also try the Write Config Tool, which will manually write the configs from the DB to the files, then try verifying again. Occasionally you'll get a ghost config file that is not in the NagiosQL database, but it's in the directory.
You could also do a:
grep -n "xi_timeperiod_24x7" *
in the /usr/local/nagios/etc directory to see where that config is showing up.
