Re: [Nagios-devel] Important check_command functionality
You may want the functionality you describe,
but is this really the right way to implement
it? Hacking the value like this means that
configuration-management code that processes
such stuff has to get decorated with a lot of
special-case handling. Would it not be better
to add a separate directive to specify this
quality?
Besides, I hate to see ! used this way. In
most computer contexts, it means NOT. Using
an exactly opposite meaning contributes to
the general rot of culture. (Yes, I know
the CSS folks have already foisted this
corruption on us. Let's not give them any
approbation for that.)
--- On Tue, 5/19/09, Ton Voon wrote:
> From: Ton Voon
> Subject: [Nagios-devel] Important check_command functionality
> To: "Nagios Developers List"
> Date: Tuesday, May 19, 2009, 3:43 PM
> Hi!,
> One neat trick that we've done in Opsview for configuring
> in a distributed environment is an "important check
> command".
> The documentation change says:
> Service templates can make use of a special rule which
> gives precedence to their check_command value. If the
> check_command is prefixed with an exclamation mark (!), then
> the template's check_command is marked as important and will
> be used over the check_command defined for the service.
> Why is this useful? Mainly when setting a different
> check_command for distributed systems. You may want to set a
> freshness threshold and a check_command that forces the
> service into a failed state, but this doesn't work with the
> normal templating system. Using this
> important flag allows the custom
> check_command to be written, but a general distributed
> template can be used to overrule the check_command when used
> on a central Nagios server.
> For instance:
> # On master
> define host{
> name
> service-distributed
> register
> 0
> active_checks_enabled 0
> check_freshness
> 1
> check_command
> !set_to_stale
> # On slave
> define host{
> name
> service-distributed
> register
> 0
> active_checks_enabled 1
> # Server configuration, used by master and slave
> define host{
> host_name
> host1
> check_command
> check_http...
> use
> service-distributed
> The patch is attached. Would this be desired in core
> Nagios?
> Ton
> -----Inline Attachment Follows-----
> Crystal Reports - New Free Runtime and 30 Day Trial
> Check out the new simplified licensing option that enables
> unlimited royalty-free distribution of the report engine
> for externally facing server and web deployment.
> http://p.sf.net/sfu/businessobjects
> Nagios-devel mailing list
> [email protected]
