[Nagios-devel] [Fwd: Re: [Nagios-users] Nagios 3.0b4 crashing]
Sorry, due to an error on my mail server, this didn't get through first
time round.
Found the cause of this: the pre-flight check isn't working correctly
(see output below) which caused the confusion (the errors were
off-screen in my terminal window, and I mistakenly trusted the "Total
Warnings: 0, Total Errors: 0" bit!!
I've copied in nagios-devel to report this (also confirmed the same with
today's CVS build.) Note that the servicegroup "Server_Info" does *not*
exist (I mistakenly removed it a few days ago), so the pre-flight check
should report it as an error, but it doesn't.
Nagios 3.0b4
Copyright (c) 1999-2007 Ethan Galstad (http://www.nagios.org)
Last Modified: 09-27-2007
License: GPL
Reading configuration data...
Error: Could not find any servicegroup matching 'Server_Info' (config
file
'/usr
/local/nagios.test/etc/services/system-uptime.cfg', starting on line 1)
file
'/usr
/local/nagios.test/etc/services/system-processes.cfg', starting on line 1)
file
'/usr
/local/nagios.test/etc/services/system-name.cfg', starting on line 1)
file
'/usr
/local/nagios.test/etc/services/system-location.cfg', starting on line 1)
file
'/usr
/local/nagios.test/etc/services/system-contact.cfg', starting on line 1)
file
'/usr
/local/nagios.test/etc/services/snmp-uptime.cfg', starting on line 1)
Checking services...
Checked 7 services.
Checking hosts...
Checked 1 hosts.
Checking host groups...
Checked 1 host groups.
Checking service groups...
Checked 1 service groups.
Checking contacts...
Checked 1 contacts.
Checking contact groups...
Checked 1 contact groups.
Checking service escalations...
Checking service dependencies...
Checked 0 service dependencies.
Checking host escalations...
Checked 0 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 4 commands.
Checking time periods...
Checked 1 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Things look okay - No serious problems were detected during the
pre-flight check
Andy
Andreas Ericsson wrote:
> Please don't top-post.
> [email protected] wrote:
>> Thanks,
>> According to the 3.0 documentation, you don't need to re-compile
>> Nagios to
>> get the debug symbols - is this right?
> No. See below.
>> "Debugging information can now be written to a separate debug file,
>> which
>> is automatically rotated when it reaches a user-defined size. This
>> should
>> make debugging problems much easier, as you don't need to recompiled
>> Nagios."
> This is about debugging symbols which reside inside the executable
> binary,
> not about debugging output generated by the program itself.
> Debugging symbols and debug output is not even remotely the same.
>> I've enabled the "allow Nagios to create core dumps" option (can't
>> remember
>> what it's called atm), and the notes for that directive do say that even
>> with that option enabled, Nagios may not create a core dump, which it
>> doesn't.
> It's supposed to. Perhaps you meant "disabled the ..." ?
>> I'll try strace/ktrace, but how do you get Nagios to run in the
>> foreground,
>> as soon as you start it with "-d" it goes to the background anyway?
> Start it without -d, or use "strace -f", although you'll still have to
> send
> the backtrace of your resulting core-dump to the nagios-devel@ mailing
> list
> if you want any help solving the problem, unless a recent CVS snapshot
> does
> the t
...[email truncated]...
