I loaded up netscape 4.x and I did not get the plugin message. I did get
the you don't have permissions, but that was because I forgot to copy
.htaccess from the previous install to my cgi directory. After correcting
the .htaccess error, the netscape 6.2 worked fine. I guess the plugin was
its attempt to fix the problem with the missing .htaccess, although it was
the wrong attempt.
David
-----Original Message-----
From: Bertelson, Tom (CAP, CARD) [mailto:[email protected]]
Sent: Wednesday, March 06, 2002 7:23 AM
To: '[email protected]'
Cc: '[email protected]'
Subject: RE: [Nagios-devel] mysql enabled - can't see data on web page
(ne tscape plugin)
I'm seeing a similar problem viewing service trends, though everything else
seems to be fine. I first noticed it with 1.0a5. I'll dig a little deeper.
From: David Edward Shapiro [mailto:[email protected]]
Sent: Tuesday, March 05, 2002 4:26 PM
Subject: [Nagios-devel] mysql enabled - can't see data on web page
(netscape plugin)
I enabled mysql support for the full monty accept objects. If I look in the
database nagios at its tables, which I created with the
contrib/create_mysql, I see data, but if I go to the web page and try to
view the data, a netscape plug-ins box pops up and tries to have me download
a plugin called NPNetRecall.jar. It is only compatible with netscape 4.x
though, and I use netscape 6. The page also says:
It appears as though you do not have permission to view information for any
of the services you requested.
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
Original poster: avid Edward Shapiro [mailto:[email protected]
