[Nagios-devel] inconsistent specfile for x86_64 arch
------_=_NextPart_001_01C81BAB.80E5E89D
Content-Type: text/plain;
charset="us-ascii"
Hi list,
=20
I just tried to buid RPM packages for nagios 3.0b5 on a x86_64 redhat
node and... compilation failed because :
Checking for unpackaged file(s): /usr/lib/rpm/check-files
/var/tmp/nagios-buildroot
error: Installed (but unpackaged) file(s) found:
/usr/lib/nagios/cgi/avail.cgi
/usr/lib/nagios/cgi/cmd.cgi
/usr/lib/nagios/cgi/config.cgi
/usr/lib/nagios/cgi/extinfo.cgi
/usr/lib/nagios/cgi/histogram.cgi
/usr/lib/nagios/cgi/history.cgi
/usr/lib/nagios/cgi/notifications.cgi
/usr/lib/nagios/cgi/outages.cgi
/usr/lib/nagios/cgi/showlog.cgi
/usr/lib/nagios/cgi/status.cgi
/usr/lib/nagios/cgi/statusmap.cgi
/usr/lib/nagios/cgi/statuswml.cgi
/usr/lib/nagios/cgi/statuswrl.cgi
/usr/lib/nagios/cgi/summary.cgi
/usr/lib/nagios/cgi/tac.cgi
/usr/lib/nagios/cgi/trends.cgi
=20
When I look in the rpm buildroot, I see this :
=20
[nagios-buildroot]# ll usr/lib/nagios/cgi/
total 3292
-rwxrwxr-x 1 root root 238544 Oct 31 11:42 avail.cgi
-rwxrwxr-x 1 root root 228400 Oct 31 11:42 cmd.cgi
-rwxrwxr-x 1 root root 194160 Oct 31 11:42 config.cgi
-rwxrwxr-x 1 root root 244208 Oct 31 11:42 extinfo.cgi
-rwxrwxr-x 1 root root 198896 Oct 31 11:42 histogram.cgi
-rwxrwxr-x 1 root root 179536 Oct 31 11:42 history.cgi
-rwxrwxr-x 1 root root 177040 Oct 31 11:42 notifications.cgi
-rwxrwxr-x 1 root root 172912 Oct 31 11:42 outages.cgi
-rwxrwxr-x 1 root root 177296 Oct 31 11:42 showlog.cgi
-rwxrwxr-x 1 root root 235792 Oct 31 11:42 status.cgi
-rwxrwxr-x 1 root root 197840 Oct 31 11:42 statusmap.cgi
-rwxrwxr-x 1 root root 189904 Oct 31 11:42 statuswml.cgi
-rwxrwxr-x 1 root root 177104 Oct 31 11:42 statuswrl.cgi
-rwxrwxr-x 1 root root 197584 Oct 31 11:42 summary.cgi
-rwxrwxr-x 1 root root 189392 Oct 31 11:42 tac.cgi
-rwxrwxr-x 1 root root 203696 Oct 31 11:42 trends.cgi
[nagios-buildroot]# ll usr/lib64/nagios/cgi/
total 12
-rwxrwxr-x 1 root root 5335 Oct 31 11:42 traceroute.cgi
=20
It looks like the non-64 libs are not packaged.
=20
When I change in the spec file references to ${_libdir} and write
instead ${_prefix}/lib (i.e : replace all occurrences of libdir with
"prefix / lib" as can be found already in the specfile) , RPM creation
succeeds...
=20
Maybe someone could correct this in the sources ?
Best regards,
=20
Frederic Schaer
Content-Type: text/html;
charset="us-ascii"
Hi list,
I just tried to buid RPM packages for nagios =
3.0b5 on
a x86_64 redhat node and… compilation failed =
because :<
...[email truncated]...
