On 2/17/2009 1:50 PM, Gerhard Lausser wrote:
> Hi,
> we could lower the latency of a similar installation with these setting=
s:
> sleep_time=3D0.01
> service_inter_check_delay_method=3D0.1
> service_interleave_factor=3D2
> =20
I will try them and let you know.
Tks a lot.
I am wondering is theat event loop would not work better if we had=20
some threads doing the high and low priority events?
[]s.
> Gerhard
> =20
>> -----Urspr=FCngliche Nachricht-----
>> Von: Alessandro Ren [mailto:[email protected]]
>> Gesendet: Dienstag, 17. Februar 2009 17:18
>> An: Nagios Developers List
>> Betreff: [Nagios-devel] High latencies problem.
>> Hello,
>> I have a nagios system running with 427 hosts and 11160
>> services and since I reached 8000 services, I am having
>> problems with the latency beeing around 100s and 200s.
>> use_large_installation_tweaks is enabled,
>> max_concurrent_checks have been tested with 0 and higher
>> values and I have tested this setup in two different HWs, a
>> dual core with 4GB RAM 32 bits a a Dual Xeon Dual core 64bits
>> with 8GB of RAM. We are using REdHat enterprise 5.
>> Also reaper is already at 2s, host checks with cache
>> horizon are enabled with a max retry of 3, all services check
>> every 5min.
>> I have no service dependency set up.
>> I've noticed that nagios is not spawning too many
>> processes as another nagios I have running which has far less
>> servicexs and it seems that the event loop if lagging behing,
>> in my debugs.
>> Any ideas what could I do to fix that? Have I reached a
>> limit in nagios pooler code?
>> Tks.
>> --=20
>> Alessandro Ren
>> http://www.opservices.com.br
>> [email protected]
>> Open Source Business Conference (OSBC), March 24-25, 2009,
>> San Francisco, CA
>> -OSBC tackles the biggest issue in open source: Open Sourcing
>> the Enterprise
>> -Strategies to boost innovation and cut costs with open
>> source participation
>> -Receive a $600 discount off the registration fee with the
>> source code: SFAD
>> http://p.sf.net/sfu/XcvMzF8H
>> _______________________________________________
>> Nagios-devel mailing list
>> [email protected]
>> https://lists.sourceforge.net/lists/lis ... gios-devel
>> =20
> Open Source Business Conference (OSBC), March 24-25, 2009, San Francisc=
o, CA
> -OSBC tackles the biggest issue in open source: Open Sourcing the Enter=
prise
> -Strategies to boost innovation and cut costs with open source particip=
ation
> -Receive a $600 discount off the registration fee with the source code:=
SFAD
> [email protected]
> =20
