Re: [Nagios-devel] [PATCH] Fix default value for
On 29 Aug 2012, at 14:05, Andreas Ericsson wrote:
> On 08/29/2012 12:49 AM, Alex Bame wrote:
>> Hello list,
>>=20
>> Sometime between 3.3.1 and 3.4.1 the default value for the
>> enable_environment_macros configuration changed from TRUE to FALSE.
>> The docs and config templates still say that TRUE is the default,
>> however.
>>=20
>> The attached patch changes it back to TRUE.
>>=20
>=20
> NAK. William provided a reasonable explanation, so I won't get into
> one. I'll make sure to mention it in the release-notes though and
> I'll also change the sample config to make sure they're set to FALSE
> by default there too.
The sample-config still has a default value of 1.
However, even with this set to true, it looks like Nagios 4 doesn't set =
the envvars. In host/service checks, it looks like no envvars are set. =
Is there a technical reason why this is not done, or is this a bug?
Ton
