[Nagios-devel] collector/proxy implementation.
Hi ...
I haven't been able to find anything like a seperate
nagios collector / proxy.
The idea is to have a seperate collector that gathers
information from nrpe's. Then nagios gets its information
from the collector (via a seperate plugin, similar to
check_nrpe).
The need for something like this comes from the need
for scalability (to have seperate collectors for seperate
environments). Or to use it as a gateway between network
borders. Is there anything similare being done?
My idea is to borrow heavily from nrpe-2.0 and do the
following:
- 'check_collector' is a plugin for nagios, it
communicates with a given collector. Has parameters
such as collector-IP, host-IP, check-command.
- 'collector' is a daemon that can work in two modes
I) transparent
II) non-transparent
* In transparent mode it will receive requests from
a specified nagios host, and blindly forward the
request to the specified host with the given command.
Received requests will be cached, and continuously
(according to a specified interval) checked. Results
will be cached at the collector. When nagios asks
for a status, cached information will be provided.
If for a certain period new requests do not arrive,
the check for that service will not be repeated.
Advantage: No need for extra configuration on the
collector. (only specification of authorized
nagios host)
Disadvantage:
- nagios host IP can be spoofed and random
checks can be executed. DOS attacks!
- initial check will probably result in timeout.
* In the Non-transparent mode extra configuration
required. host:command pairs need to be entered
to specify which checks are allowed.
checks will continue independent from requests generated
by the nagios host. When a request is made, cached
Advantage: In case of a DOS attack, monitored systems
will not be directly bothered.
Disadvantage: One more system will have to be configured.
Any ideas, comments and pointers welcome...
gd
